Si522xx Si52212 Si52208 Si52204 Si52202 FAQ
by <a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Ninja Employee</font></font> </a> tihopkin on ‎09-12-2017 06:03 PM - edited on ‎09-21-2017 03:44 PM by <a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Star Employee</font></font> </a> tpaluck
General Questions
  1. Where can I find datasheets and user guides for Si522xx?
Datasheet: https://www.silabs.com/documents/public/data-sheets/si522xx-datasheet.pdf
Si52204 Evaluation Kit (EVB): https://www.silabs.com/products/development-tools/timing/clock/si52204-evb-evaluation-kit
EVB User Guide: https://www.silabs.com/documents/public/user-guides/ug277-si52204-evb.pdf
Some Helpful Application Notes
Description of the new PCI Express 4.0 Jitter Requirements:
https://www.silabs.com/documents/public/application-notes/an946-pci-express-jitter-requirements.pdf
Help on converting HCSL Signals to either LVPECL, LVDS, or CML:
https://www.silabs.com/documents/public/application-notes/an781-alternative-output-termination.pdf
Tips for driving longer PCI Express clock lines:
https://www.silabs.com/documents/public/application-notes/an871-driving-long-pcie-clock-lines.pdf
  1. Where can I find more information regarding the Si522xx's PCIe performance?
Try looking in our PCI Express Learning Center: https://www.silabs.com/products/timing/pci-express-learning-center
There you can download our PCIE Express Clock Jitter Tool and see sample data files from the Si52204.
  1. Where can I find quality and reliability documents for Si522xx?
Try our RFI Portal: https://ops.silabs.com/wrfi/pages/PartSearch
If you aren’t able to find the needed documents there, try emailing our quality team at:  DL.RFISupport@silabs.com
  1. Want sample parts?
We are currently giving out samples for Si52202-A01, Si52204-A01, Si52208-A01, and Si52212-A01. To request one, select the sample option beneath the desired part number in our PCIe Clock Generator Product Matrix.
https://www.silabs.com/products/timing/clocks/pcie-clock-generators
Part Specific Questions
Si52202
  1. What is the I2C address for Si52202?
Since Si52202 does not have a REF/SA pin to select the I2C address, the address will always be set to 0x6A.
