Question about EZR32LG230F256R68 radio-config-wds-gen.h
Hi All,
I have problem with radio startup of EZR32LG230F256R68 chip. My radio hangs in ezradio_comm_SendCmdGetResp() function called with parametres from RADIO_CONFIGURATION_DATA_ARRA in generated file radio-config-wds-gen.h. Is there some kind of document in which I can find explanation of parameters generated in mentioned file?
Thanks in advance
Re: Question about EZR32LG230F256R68 radio-config-wds-gen.h
The document explaining of parameters can be found in https://www.silabs.com/documents/public/application-notes/EZRadioPRO_REVC2_API.zip
It is very important to set the chip type and chip revision correctly, corresponding to the device.
Best regards,
Tamas
