How to create project for custom EFR32 board ?
I am new with Silabs products and ARM MCU.
I am a student and I must realize a prototype for a company.
What I need to do:
  • A program with UART communication and a range test for a sub-GHz frequency of 868MHz. I made a customized card with an EFR32FG12P431F1024GM48.
I think the best solution is to use emlib for UART and RAIL for RF. But I do not know how to create a new project.
The solutions I have tried are:
  1. New Project -> Silicon Labs AppBuilder Project -> Silicon Labs Flex SDK -> RAIL: Simple TRX -> Generate
    Several BSP errors !
    I saw in HAL->Board Header Configuration->Custom created header I can open a custom header but I don't know how to make one
  2. New project -> Silicon Labs AppBuilder Project -> Silicon Labs Flex SDK -> Start with a blank application -> Plugins: RAIL Common -> Generate
    Many errors with missing files !
  3. New Silicon Labs Project (Hardware Configurator)
    I can build the project but I don't know how to use the RF part
The differents documents / videos I have seen are for starter kits and they don't seem to work for a custom board.
Have you any specific documentation for a custom board ?
What is the easiest way to create a new project? from an example? If so, what is the difference between RAIL and Connect?.
I'm sorry for my writing, English isn't my first language
IDE : Simplicity Studio V4
SDK: Flex SDK 1.2.1.0
SoC: EFR32FG12P431F1024GM48
Kit : Custom Board
Re: How to create project for custom EFM32 board ?
Admin/Moderator, can you edit subject to "How to create project for custom EFR32 board ?" please...
