EFR32 RAILCb_RxPacketReceived latched rssi and time values always 0
When receiving packets with RAILCb_RxPacketReceived, the rssiLatch and timeUs values within rxPacketInfo are always 0.
The chip I am using is EFR32FG
Does any one have any ideas?
Re: EFR32 RAILCb_RxPacketReceived latched rssi and time values always 0
RAIL_RxConfig actually implements input parameter appendedInfoEnable, that Enable/Disable appended info.
Tamás
Silicon Labs
Thanks,  now it is working.
However, in the comments of the function API in rail.h it says:
appendedInfoEnable Enable/Disable appended info (not implemented)
So I thought the parameter was not used.
