WDS 3.2.11.0 Release Notes
by <a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Hero Employee</font></font> </a> zopapp ‎03-08-2017 08:23 AM - edited ‎03-08-2017 08:24 AM
Since you will only see the release notes once when you install the new version, here it is for reference:
Maximum data rate restriction based on XO frequency introduced in Range Test project
Help text added to Enable IQ calibration control
DSA detection offered in antenna diversity Rx mode on Si446x C2A/A2A revisions
PSM (Preamble Sense Mode) Rx mode configuration update
Description of Custom packet Rx with PSM project updated
New FW patch added for C2A Si446x revision that fixes a PSM related bug
New FW patch added for A2A Si446x revision in PSM Rx mode that fixes a PSM related bug
Auto frequency hop Rx configuration update when DSA is enabled
Introduced preamble pattern selection "Std. 1010 pattern (>= 16 and < 32 bits)" for DSA detection
Help text updated at Enable DSA control
Data rate and preamble length unit changed to ksps and sbytes, respectively  in 4(G)FSK mode for clarity
Description of Manual frequency hop Rx project updated
PSM (Preamble Sense Mode) Rx mode introduced
High power PA ramp down early shut off issue fixed
Labels updated on CRC check boxes in 802.15.4g bidirectional packet project
Manchester decoding on preamble restricted to no-standard preamble pattern selections
Manchester on Constant 1's or 0's control restricted to Tx projects only
Bit order radio button behavior changed on the Packet configuration to fix a Si446x B1B revision related bug
Non-standard preamble pattern byte order reversed to match over the air pattern with GUI
Direct Tx project configuration updated with matching Rx configurations
PA power level control made unavailable in the Range Test project
