EZRadioPRO vs EZR32 PA matching network
by <a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Hero Employee</font></font> </a> dasimon ‎11-16-2016 09:30 AM - edited ‎11-16-2016 09:31 AM
Can I use the same matching network for EZRadioPRO and an EZR32 wireless MCU that is based on the same radio?
The answer depends on the actual PCB layer stack-up as the distance between the top and the first inner (ground) layer determines the PCB parasitic capacitances, which plays part in the matching network.
If the same PCB layer stack-up is used (or at least the distance between the top and the first inner layer is similar), in that case the same matching network component values should result very similar TX and RX performance for an EZRadioPRO radio and an EZR32 wireless MCU. If the PCB layer stack-up deviates significantly, it is not recommended to use the same matching network as the detuning can cause lower output power, higher harmonics, higher current consumption and sensitivity loss.
