TS1105 Confusion
Having trouble understanding the use of this part.  The spec does't go all the way to describe how someone gets an accurate current result. You get a linear graph of results but then you have to mess with results to get current - and this isn't described.  The eval board spec gives you a test instead of showing results. Then:
I look at this: (use 3V VDD and 1.5Vbias example chart page11 of spec)
Is=2A
Rs=.01
Vs=20mV
Vout(20)=.4
but the example chart shows Vout at .4V to be something like a 55mV Vs.
Why different?
Re: TS1105 Confusion
every app will have a different Rsense, so it would be impossible to put the current value in the datasheet.
strangely, this is a SILbs part DigiKey does not carry
