Si5340 2 different datasheets
Hello Dear Silicon Labs,
i want to use in my design following part : Si5340A. I found on your web 2 different datasheets regarding the maximum output frequency for this part:
1st - https://www.silabs.com/documents/public/data-sheets/Si5341-40-D-DataSheet.pdf
2nd - https://www.silabs.com/documents/public/data-sheets/Si5341-40.pdf
Can you please provide the correct one between those two?
Anton
<a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Genius</font></font> </a> CL
Re: Si5340 2 different datasheets
The "Rev-D" document has a newer date.
See AN1006: Differences Between Si534x/8x Revision B and Revision D Silicon (PDF):
SUMMARY
Compared to Revision B, Revision D silicon for Si534x/8x fixes several errata, supports higher maximum output frequency ranges, and offers several new features.
Thanks for the help CL,
Yes, now I'm good to continue with the design.
Anton
