demo source code for IRMFB-EK
I failed to rebuild the demo source code (bottom side) associated with IRMFB-EK by using Silicon liboratories IDE.  The message is "output file not found: c:\...\PT-Bridge".
I want to learn the code by debugging on the IRMFB. can anyone help me out?
Thanks a lot!
victoria
Re: demo source code for IRMFB-EK
It seems like you're getting an error building the source code. Can you first check if you have the Keil PK51 registered? Here is the link: http://pages.silabs.com/lp-keil-pk51.html
If it's not registered, you will get limited space for compiling the project.
Tony
Hi Tony:
Thanks a lot! Porblem is solved after your advice.
Best,
victoria
