Sensor Puck stopped working
The LED to the left of the on/off switch is solid red and the iPad application does not see the sensor.  It worked fine for a few weeks before this.  The battery is fine.
Is there a way to reset the device or is it dead.
Re: Sensor Puck stopped working
The red LED indicates a hardware problem. You can try removing the battery for a few minutes then try again to see if it makes any difference.
Thanks, but after leaving the battery out for many minutes, I still have the problem.  Red light stays on.  It appears this guy is dead.  :-(
