Zigbee Network Impelementing Limitations and Best modules
Hi every body,
I have some questions about Zigbee Network Impelementing Limitations and finding better modules.
1- How many nodes (max) can add in zigbee pro mesh network practicaly?
2- What is the main limitation factors for zigbee MCUs that can not support more than a limited number of nodes(for example 250 nodes)?
3- If i have a big or large network (for example 2000 nodes in a Hotel) what chip do you offer me?
4- In practical, Which of the SiliconLabs modules are better for large zigbee networks?
Thanks.
<a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Hero</font></font> </a> YK
Re: Zigbee Network Impelementing Limitations and Best modules
There's a case study at http://community.silabs.com/t5/Video-Tutorials/ZigBee-Case-Study-in-Large-Node-Network/td-p/129528 . I would suggest you to use EFR32 instead of EM35x for new Zigbee design.
If my reply answers your question, please click on "Kudo"s or "Accept as Solution"s to benefit others who have the same issue.
YK Chen
Thanks a lot. This case was create for my application. SO Great.Heart
Hi again YK,
I have a new question. Is other stack software (such as ti z-stack 3.0.1) interoperable with EmberZNet pro?
I want to create my hub or gateway with EFR32 because of its memory and power and create other nodes with other cheaper modules. Is it possible?
 Another question is: If i register kit for simplicity studio 4 once, Can I work with EmberZNet forever?
Thanks.
I use both and they have no problem to work to each other.
YK Chen
Yes. If you register kit for simplicity studio 4 once, you can work with EmberZNet forever.
YK Chen
Can I increase the number of nodes connected to the network with this model? (ERF32 for coordinator and other cheaper chip for router or end device - for hotel application)
Yes, you can do that.
YK Chen
thank you dear YK. You are the best.
