How to generate SPI Host App
Following this guide:
https://www.silabs.com/documents/public/application-notes/AN912-SPI-Host-Configuration.pdf
in part 3: Building and Using Host Applications they talk about working with files on the pi that are generated (I assume) through Simplicity Studios.
"The Linux host is loaded with the spi-server application, the ip-driver-app, and the top-level host application"
How do I generate these applications?
Re: How to generate SPI Host App
Those applications come with our stack.  If you have transferred the whole stack over to the raspberry pi, you can follow the instructions on step 3 there and build the applications.
