HAL Configuration Options Table Part 2
by <a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Hero Employee</font></font> </a> ADKates on ‎06-12-2017 05:29 PM
This is a continuation of the HAL Config Options Table
Back to Table Part 1
Back to Migrating to the new HAL Config file format for EFR32
PTA
BSP_PTA_GNT_ASSERT_LEVEL
0 or 1
PTA grant assert signal level
PTA
BSP_PTA_GNT_PIN
0-15
PTA grant pin
PTA
BSP_PTA_GNT_PORT
GPIO_Port_TypeDef
PTA grant port
PTA
BSP_PTA_PRI_ASSERT_LEVEL
0 or 1
PTA priority assert signal level
PTA
BSP_PTA_PRI_PIN
0-15
PTA priority pin
PTA
BSP_PTA_PRI_PORT
GPIO_Port_TypeDef
PTA priority port
PTA
BSP_PTA_REQ_ASSERT_LEVEL
0 or 1
PTA request assert signal level
PTA
BSP_PTA_REQ_PIN
0-15
PTA request pin
PTA
BSP_PTA_REQ_PORT
GPIO_Port_TypeDef
PTA request port
PTA
BSP_PTA_REQ_SHARED
0 or 1
Configure PTA request signal for shared mode
PTA
HAL_PTA_ENABLE
0 or 1
Enable packet traffic arbitration
PTA
HAL_PTA_OPTIONS
HalPtaOptions
PTA options
PTI
BSP_PTI_DCLK_LOC
_FRC_ROUTELOC0_DCLKLOC_LOCn
PTI DCLK location (may be defined for SPI)
PTI
BSP_PTI_DCLK_PIN
0-15
PTI DCLK pin (may be defined for SPI)
PTI
BSP_PTI_DCLK_PORT
GPIO_Port_TypeDef
PTI DCLK port (may be defined for SPI)
PTI
BSP_PTI_DFRAME_LOC
_FRC_ROUTELOC0_DFRAMELOC_LOCn
PTI DFRAME location (may be defined for UART/SPI)
PTI
BSP_PTI_DFRAME_PIN
0-15
PTI DFRAME pin (may be defined for UART/SPI)
PTI
BSP_PTI_DFRAME_PORT
GPIO_Port_TypeDef
PTI DFRAME port (may be defined for UART/SPI)
PTI
BSP_PTI_DOUT_LOC
_FRC_ROUTELOC0_DOUTLOC_LOCn
PTI DOUT location (must be defined)
PTI
BSP_PTI_DOUT_PIN
0-15
PTI DOUT pin (must be defined)
PTI
BSP_PTI_DOUT_PORT
GPIO_Port_TypeDef
PTI DOUT port (must be defined)
PTI
BSP_PTI_PRESENT
0 or 1
PTI is present
PTI
HAL_PTI_BAUD_RATE
uint32_t
PTI baud rate
PTI
HAL_PTI_ENABLE
0 or 1
Enable PTI
PTI
HAL_PTI_MODE
HAL_PTI_MODE_SPI, HAL_PTI_MODE_UART, HAL_PTI_MODE_UART_ONEWIRE
PTI Mode. Required signals per mode:
SPI: DOUT+DCLK+DFRAME
UART (one wire): DOUT
UART: DOUT+DFRAME
RHO
BSP_RHO_ASSERT_LEVEL
0 or 1
Radio hold off assert signal level
RHO
BSP_RHO_PIN
0-15
Radio hold off pin
RHO
BSP_RHO_PORT
GPIO_Port_TypeDef
Radio hold off port
RHO
HAL_RHO_ENABLE
0 or 1
Enable radio hold off. HAL_RHO_ASSERT_LEVEL, HAL_RHO_PORT, and HAL_RHO_PIN must be defined.
SERIAL
HAL_SERIAL_APP_PORT
HAL_SERIAL_PORT_VCP, HAL_SERIAL_PORT_USART0, HAL_SERIAL_PORT_USART1, HAL_SERIAL_PORT_USART2, HAL_SERIAL_PORT_LEUART0, HAL_SERIAL_PORT_LEUART1, HAL_SERIAL_PORT_USB
Port for application serial communication
SERIAL
HAL_SERIAL_ASSERT_PORT
Port for assert serial communication
SERIAL
HAL_SERIAL_LEUARTn_ENABLE
0 or 1
Enable LEUARTn serial use
SERIAL
HAL_SERIAL_RXWAKE_ENABLE
0 or 1
Enable wake from activity on RX GPIO of application port
SERIAL
HAL_SERIAL_UARTn_ENABLE
0 or 1
Enable UARTn serial use
SERIAL
HAL_SERIAL_USARTn_ENABLE
0 or 1
Enable USARTn serial use
SERIAL
HAL_SERIAL_USB_ENABLE
0 or 1
Enable USB serial use
SERIAL
HAL_SERIAL_VCOM_ENABLE
0 or 1
Enable VCOM (does not enable underlying UART)
SERIAL
HAL_SERIAL_VUART_ENABLE
0 or 1
Enable VUART serial use
SPINCP
BSP_SPINCP_NHOSTINT_PIN
0-15
SPI NCP nHOST_INT pin
SPINCP
BSP_SPINCP_NHOSTINT_PORT
GPIO_Port_TypeDef
SPI NCP nHOST_INT port
SPINCP
BSP_SPINCP_NWAKE_PIN
0-15
SPI NCP nWAKE pin
SPINCP
BSP_SPINCP_NWAKE_PORT
GPIO_Port_TypeDef
SPI NCP nWAKE port
SPINCP
BSP_SPINCP_USART_PORT
0-4
SPI NCP USART port
UARTNCP
BSP_UARTNCP_USART_PORT
UART NCP USART port
USART
BSP_USARTn_CLK_LOC
_USART_ROUTELOC0_CLKLOC_LOCn
USARTn CLK location (SPI)
USART
BSP_USARTn_CLK_PIN
0-15
USARTn CLK pin (SPI)
USART
BSP_USARTn_CLK_PORT
GPIO_Port_TypeDef
USARTn CLK port (SPI)
USART
BSP_USARTn_CS_LOC
_USART_ROUTELOC0_CSLOC_LOCn
USARTn CS location (SPI)
USART
BSP_USARTn_CS_PIN
0-15
USARTn CS pin (SPI)
USART
BSP_USARTn_CS_PORT
GPIO_Port_TypeDef
USARTn CS port (SPI)
USART
BSP_USARTn_CTS_LOC
_USART_ROUTELOC1_CTSLOC_LOCn
EFR32
USARTn CTS location (UART)
USART
BSP_USARTn_CTS_PIN
0-15
USARTn CTS pin (UART)
USART
BSP_USARTn_CTS_PORT
GPIO_Port_TypeDef
USARTn CTS port (UART)
USART
BSP_USARTn_MISO_LOC
_USART_ROUTELOC0_RXLOC_LOCn
EFR32
USARTn MISO location (SPI)
USART
BSP_USARTn_MISO_PIN
0-15
USARTn MISO pin (SPI)
USART
BSP_USARTn_MISO_PORT
GPIO_Port_TypeDef
USARTn MISO port (SPI)
USART
BSP_USARTn_MOSI_LOC
_USART_ROUTELOC0_TXLOC_LOCn
EFR32
USARTn MOSI location (SPI)
USART
BSP_USARTn_MOSI_PIN
0-15
USARTn MOSI pin (SPI)
USART
BSP_USARTn_MOSI_PORT
GPIO_Port_TypeDef
USARTn MOSI port (SPI)
USART
BSP_USARTn_ROUTE_LOC
_USART_ROUTE_LOCATION_LOCn
EZR32
USARTn route location
USART
BSP_USARTn_RTS_LOC
_USART_ROUTELOC1_RTSLOC_LOCn
EFR32
USARTn RTS location (UART)
USART
BSP_USARTn_RTS_PIN
0-15
USARTn RTS pin (UART)
USART
BSP_USARTn_RTS_PORT
GPIO_Port_TypeDef
USARTn RTS port (UART)
USART
BSP_USARTn_RX_LOC
EFR32
USARTn RX location (UART)
USART
BSP_USARTn_RX_PIN
0-15
USARTn RX pin (UART)
USART
BSP_USARTn_RX_PORT
GPIO_Port_TypeDef
USARTn RX port (UART)
USART
BSP_USARTn_TX_LOC
EFR32
USARTn TX location (UART)
USART
BSP_USARTn_TX_PIN
0-15
USARTn TX pin (UART)
USART
BSP_USARTn_TX_PORT
GPIO_Port_TypeDef
USARTn TX port (UART)
USART
HAL_USARTn_BAUD_RATE
uint32_t
USARTn baud rate (must be less than refFreq/oversampling)
USART
HAL_USARTn_FLOW_CONTROL
HAL_USART_FLOW_CONTROL_NONE,
HAL_USART_FLOW_CONTROL_SW,
HAL_USART_FLOW_CONTROL_HW,
HAL_USART_FLOW_CONTROL_HWUART
USARTn flow control mode (UART)
USART
HAL_USARTn_RX_QUEUE_SIZE
uint16_t
USARTn RX buffer size (must be a multiple of HAL_USARTn_RXSTOP)
USART
HAL_USARTn_RXSTART
uint16_t; multiple of rxstop
USARTn release flow control threshold (must be a multiple of HAL_USARTn_RXSTOP)
USART
HAL_USARTn_RXSTOP
uint16_t
USARTn assert flow control threshold
USART
HAL_USARTn_TX_QUEUE_SIZE
uint16_t
USARTn TX buffer size
VCOM
BSP_VCOM_CTS_LOC
EFR32
VCOM CTS location
VCOM
BSP_VCOM_CTS_PIN
0-31
VCOM CTS pin
VCOM
BSP_VCOM_CTS_PORT
GPIO_Port_TypeDef
VCOM CTS port
VCOM
BSP_VCOM_ENABLE_PIN
0-15
VCOM enable pin
VCOM
BSP_VCOM_ENABLE_PORT
GPIO_Port_TypeDef
VCOM enable port
VCOM
BSP_VCOM_IOEXP_ENABLE
0 or 1
VCOM is enabled via IO expander
VCOM
BSP_VCOM_PRESENT
0 or 1
VCOM availability
VCOM
BSP_VCOM_ROUTE_LOC
EZR32
VCOM route location
VCOM
BSP_VCOM_RTS_LOC
EFR32
VCOM RTS location
VCOM
BSP_VCOM_RTS_PIN
0-31
VCOM RTS pin
VCOM
BSP_VCOM_RTS_PORT
GPIO_Port_TypeDef
VCOM RTS port
VCOM
BSP_VCOM_RX_LOC
EFR32
VCOM RX location
VCOM
BSP_VCOM_RX_PIN
0-31
VCOM RX pin
VCOM
BSP_VCOM_RX_PORT
GPIO_Port_TypeDef
VCOM RX port
VCOM
BSP_VCOM_TX_LOC
EFR32
VCOM TX location
VCOM
BSP_VCOM_TX_PIN
0-31
VCOM TX pin
VCOM
BSP_VCOM_TX_PORT
GPIO_Port_TypeDef
VCOM TX port
VCOM
BSP_VCOM_USART
USARTn
USART connected to VCOM (must not define USART BSP settings for selected USART)
WDOG
HAL_WDOG_ENABLE
0 or 1
Enable watchdog
