HAL Configuration Options Table Part 1
by <a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Hero Employee</font></font> </a> ADKates ‎06-12-2017 05:26 PM - edited ‎06-12-2017 05:30 PM
Module
Define
Values
Device Specific?
Description
ANTDIV
BSP_ANTDIV_NSEL_PIN
0-15
Complementary antenna select pin
ANTDIV
BSP_ANTDIV_NSEL_PORT
GPIO_Port_TypeDef
Complementary antenna select port
ANTDIV
BSP_ANTDIV_PRESENT
0 or 1
Antenna diversity present. SEL signal must be defined, NSEL is optional.
ANTDIV
BSP_ANTDIV_SEL_PIN
0-15
Antenna select pin
ANTDIV
BSP_ANTDIV_SEL_PORT
GPIO_Port_TypeDef
Antenna select port
ANTDIV
HAL_ANTDIV_ENABLE
0 or 1
Enable antenna diversity. SEL signal must be defined, NSEL is optional.
BTL_BUTTON
HAL_BTL_BUTTON_ENABLE
0 or 1
Enable bootloader entry via button press
BTL_BUTTON
HAL_BTL_BUTTON_PIN
0-15
Bootloader entry button pin
BTL_BUTTON
HAL_BTL_BUTTON_PORT
GPIO_Port_TypeDef
Bootloader entry button port
BUTTON
BSP_BUTTON_COUNT
uint8_t
Number of buttons available
BUTTON
BSP_BUTTON_GPIO_DOUT
HAL_GPIO_DOUT_LOW, HAL_GPIO_DOUT_HIGH
DOUT value of button pins. High/low for pullup/pulldown, high for filter on input only mode.
BUTTON
BSP_BUTTON_GPIO_MODE
HAL_GPIO_MODE_INPUT, HAL_GPIO_MODE_INPUT_PULL, HAL_GPIO_MODE_INPUT_PULL_FILTER
GPIO mode of button pins
BUTTON
BSP_BUTTON_INIT
{{HAL_BUTTON0_PORT,HAL_BUTTON0_PIN}, …{HAL_BUTTONn_PORT, HAL_BUTTONn_PIN}}
Array of button port and pin numbers. Must be BSP_BUTTON_COUNT length.
BUTTON
BSP_BUTTONn_PIN
0-15
Pin # of BUTTONn
BUTTON
BSP_BUTTONn_PORT
GPIO_Port_TypeDef
Port of BUTTONn
BUTTON
HAL_BUTTON_COUNT
uint8_t
Number of buttons to enable
BUTTON
HAL_BUTTON_ENABLE
{uint8_t, uint8_t … }
Array of button indicies to enable
CLK
BSP_CLK_HFXO_FREQ
uint32_t
HFXO frequency
CLK
BSP_CLK_HFXO_INIT
CMU_HFXOInit_TypeDef
HFXO initialization settings
CLK
BSP_CLK_HFXO_PRESENT
0 or 1
HFXO availability
CLK
BSP_CLK_LFXO_FREQ
uint32_t
LFXO frequency
CLK
BSP_CLK_LFXO_INIT
CMU_LFXOInit_TypeDef
LFXO initialization settings (optional)
CLK
BSP_CLK_LFXO_PRESENT
0 or 1
LFXO availability
CLK
HAL_CLK_HFCLK_SOURCE
HAL_CLK_HFCLK_SOURCE_HFRCO, HAL_CLK_HFCLK_SOURCE_HFXO
Oscillator source for the high frequency clock tree
CLK
HAL_CLK_LFCLK_SOURCE
HAL_CLK_LFCLK_SOURCE_LFRCO, HAL_CLK_LFCLK_SOURCE_LFXO
Oscillator source for the low frequency clock trees (LFA, LFB)
DCDC
BSP_DCDC_INIT
EMU_DCDCInit_TypeDef
EFR32
DCDC initialization options
DCDC
BSP_DCDC_PRESENT
0 or 1
EFR32
Power circuit configured for DCDC
DCDC
HAL_DCDC_BYPASS
0 or 1
EFR32
Override DCDC mode to bypass mode (when board is configured for DCDC)
EXTDEV
BSP_EXTDEV_CS_PIN
0-15
External device nSEL/CS pin
EXTDEV
BSP_EXTDEV_CS_PORT
GPIO_Port_TypeDef
External device nSEL/CS port
EXTDEV
BSP_EXTDEV_INT_PIN
0-15
External device interrupt pin
EXTDEV
BSP_EXTDEV_INT_PORT
GPIO_Port_TypeDef
External device interrupt port
EXTDEV
BSP_EXTDEV_SDN_PIN
0-15
External device shutdown pin
EXTDEV
BSP_EXTDEV_SDN_PORT
GPIO_Port_TypeDef
External device shutdown port
EXTDEV
HAL_EXTDEV_ENABLE
0 or 1
Enable external device driver
EXTFLASH
BSP_EXTFLASH_CS_PIN
0-15
Spiflash chip select pin
EXTFLASH
BSP_EXTFLASH_CS_PORT
GPIO_Port_TypeDef
Spiflash chip select port
EXTFLASH
BSP_EXTFLASH_HOLD_PIN
0-15
Spiflash hold pin
EXTFLASH
BSP_EXTFLASH_HOLD_PORT
GPIO_Port_TypeDef
Spiflash hold port
EXTFLASH
BSP_EXTFLASH_MISO_LOC
_USART_ROUTELOC0_RXLOC_LOCn
EFR32
Spiflash MISO location
EXTFLASH
BSP_EXTFLASH_MISO_PIN
0-15
Spiflash MISO pin
EXTFLASH
BSP_EXTFLASH_MISO_PORT
GPIO_Port_TypeDef
Spiflash MISO port
EXTFLASH
BSP_EXTFLASH_MOSI_LOC
_USART_ROUTELOC0_TXLOC_LOCn
EFR32
Spiflash MOSI location
EXTFLASH
BSP_EXTFLASH_MOSI_PIN
0-15
Spiflash MOSI pin
EXTFLASH
BSP_EXTFLASH_MOSI_PORT
GPIO_Port_TypeDef
Spiflash MOSI port
EXTFLASH
BSP_EXTFLASH_SCLK_LOC
_USART_ROUTELOC0_CLKLOC_LOCn
EFR32
Spiflash CLK location
EXTFLASH
BSP_EXTFLASH_SCLK_PIN
0-15
Spiflash CLK pin
EXTFLASH
BSP_EXTFLASH_SCLK_PORT
GPIO_Port_TypeDef
Spiflash CLK port
EXTFLASH
BSP_EXTFLASH_USART
USARTn
USART connected to spiflash
EXTFLASH
BSP_EXTFLASH_USART_CLK
CMU_Clock_TypeDef (USART only)
Clock for spiflash USART
EXTFLASH
BSP_EXTFLASH_WP_PIN
0-15
Spiflash write protect pin
EXTFLASH
BSP_EXTFLASH_WP_PORT
GPIO_Port_TypeDef
Spiflash write protect port
EXTFLASH
HAL_EXTFLASH_USART_BAUDRATE
uint32_t
Baudrate for spiflash USART
EZRADIOPRO
BSP_EZRADIOPRO_FREQ
uint8_t
PRO2+ SPI frequency in MHz
EZRADIOPRO
BSP_EZRADIOPRO_USART
USARTn
USART connected to the PRO2+ transceiver
EZRADIOPRO
HAL_EZRADIOPRO_SHUTDOWN_SLEEP
0 or 1
Shutdown PRO2+ when sleeping
LED
BSP_LED_COUNT
uint8_t
Number of LEDs available
LED
BSP_LED_INIT
{{HAL_LED0_PORT, HAL_LED0_PIN},
...{HAL_LEDn_PORT, HAL_LEDn_PIN}}
Array of LED port and pin numbers. Must be BSP_LED_COUNT length.
LED
BSP_LEDn_PIN
0-15
Pin # of LEDn
LED
BSP_LEDn_PORT
GPIO_Port_TypeDef
Port of LEDn
LED
HAL_LED_COUNT
uint8_t
Number of LEDs to enable
LED
HAL_LED_ENABLE
Array of LED indicies to enable
PA
HAL_PA_2P4_ENABLE
0 or 1
EFR32
Enable 2.4GHz PA
PA
HAL_PA_2P4_OFFSET
int16_t
EFR32
Output power offset in dBm * 10(2.4GHz)
PA
HAL_PA_2P4_POWER
int16_t
EFR32
Desired output power in dBm * 10 (2.4GHz)
PA
HAL_PA_2P4_RAMP
int16_t
EFR32
Desired ramp time in us (2.4GHz)
PA
HAL_PA_2P4_VOLTMODE
RADIO_PAVoltMode
EFR32
2.4GHz PA voltage mode
PA
HAL_PA_SUBGIG_ENABLE
0 or 1
EFR32
Enable Sub-GHz PA
PA
HAL_PA_SUBGIG_OFFSET
int16_t
EFR32
Output power offset in dBm * 10(Sub-GHz)
PA
HAL_PA_SUBGIG_POWER
int16_t
EFR32
Desired output power in dBm (Sub-GHz)
PA
HAL_PA_SUBGIG_RAMP
int16_t
EFR32
Desired ramp time in us (Sub-GHz)
PA
HAL_PA_SUBGIG_VOLTMODE
RADIO_PAVoltMode
EFR32
Sub-GHz PA voltage mode
On to Table Part 2
Back to Migrating to the new HAL Config file format for EFR32
