cpt112s i2c
hi everyone,
      i follow the standard i2c protocol to communicate with cpt112s but i don't get ack on i2c. the communication start when INT pin goes low. my i2c communication code below attached. please help me.
Re: usbhost.exe erroor opening device
@harringt
Could I know which part you are using?
Is this is a USB bridge part like CP210x? is the board you are testing a evaluation board from Silabs or made my yourself?
If this is a MCU part with USB function from Silabs, what software you have programmed into it?
I am not familiar with usbhost.exe tool, is it a free test tool, where you get it?
I am using EFM32GG3301024. The board is not an evaluation board. I have programmed the device with the usbconfig.h, my program, the descriptors. I also have programmed my device with a USB bootloader. I know the boot loader and my program are running together. I got usbhost.exe from AN0065.
@harringt
I saw you put an ticket 00138763 in our support portal. let track this issue with that ticket.
