How to disable playback on CP2114 B01?
     From the datasheet I gather there is a option to disable playback(Byte 43, Bit 3) on B02 chips. But for B01 chips there are only 29 configuration bytes. Is there a way to disable playback on B01?
Many Thanks,
Tony
Re: How to disable playback on CP2114 B01?
Hi @tonysonney,
The playback function cannot be disabled for B01 revision. Recommend using B02 if necessary.
Jiehui
Thank you for the information Jiehui.
