CP2114 configuration spreadsheet
Ive been trying all kinds of combinations of config strings to test different CP2114 setups so I made a little excel spreadsheet that makes the process a lot easier (for me anyway).
I only really edit the audio and system property binaries so it saves me a bunch of time as it does the binary conversion to hex. The final string box can then be copied and pasted into the CP2114 config tool. The config string also includes the FC 01 bits at the end to force a device reset with the new settings applied.
Hope it helps someone!
Charlie
Re: CP2114 configuration spreadsheet
Hi Charlie,
Thank you for your sharing!
Jiehui
