CP2114 b01: Errata CP2114_E107 trigger
        What was triggering this error? I have a similar problem, except which the workaround of rebooting twice does not help. So far the only way I could get it to work is by resetting the audio bridge (either by reset pin or unplug/replug usb).
So if I know what was triggering the problem, I could (avoid the failing trigger or) generate the trigger which made it recover.
Many Thanks,
Tony
Re: CP2114 b01: Errata CP2114_E107 trigger
You may want to inquire directly to support about this as I'm not sure how sensitive the information you're looking for is. Go to Contact Support at:
http://www.silabs.com/support
Thankyou Alan.
