回复
发帖数: 8
注册日期: ‎07-28-2017
SLSTK3400 使用问题
发帖数: 2,384
注册日期: ‎10-14-2014
回复: SLSTK3400 使用问题
@aple
应该是编译没成功。查查哪儿出错了。
发帖数: 8
注册日期: ‎07-28-2017
回复: SLSTK3400 使用问题
这是开发板的列子,没有改程序,以前都可以,不知道为什么现在不行了。
发帖数: 8
注册日期: ‎07-28-2017
回复: SLSTK3400 使用问题
打开错误列表:
Program file does not exist
C:\Users\endb052\SimplicityStudio\v3_workspace\SLSTK3400A_textdisplay\GNU ARM v4.8.3 - Debug\SLSTK3400A_textdisplay.axf not found
发帖数: 2,384
注册日期: ‎10-14-2014
回复: SLSTK3400 使用问题
@aple
I suggest you upload the whole log in the "console" view during the building process.
This message that you saw indicate the build process failed and did not produce the file.
发帖数: 8
注册日期: ‎07-28-2017
回复: SLSTK3400 使用问题
11:28:44 **** Incremental Build of configuration GNU ARM v4.8.3 - Debug for project SLSTK3400A_textdisplay_4 ****
make -j4 all
Building file: ../src/main.c
Building file: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_leuart.c
Invoking: GNU ARM C Compiler
arm-none-eabi-gcc -g -gdwarf-2 -mcpu=cortex-m0plus -mthumb '-DDEBUG_EFM=1' '-DEFM32HG322F64=1' '-DDEBUG=1' -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/examples/textdisplay" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/config" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/CMSIS/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/bsp" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/drivers" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/Device/SiliconLabs/EFM32HG/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd/ssd2119" -O0 -Wall -c -fmessage-length=0 -mno-sched-prolog -fno-builtin -ffunction-sections -fdata-sections -std=c99 -MMD -MP -MF"src/main.d" -MT"src/main.o" -o "src/main.o" "../src/main.c"
arm-none-eabi-gcc -g -gdwarf-2 -mcpu=cortex-m0plus -mthumb '-DDEBUG_EFM=1' '-DEFM32HG322F64=1' '-DDEBUG=1' -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/examples/textdisplay" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/config" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/CMSIS/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/bsp" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/drivers" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/Device/SiliconLabs/EFM32HG/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd/ssd2119" -O0 -Wall -c -fmessage-length=0 -mno-sched-prolog -fno-builtin -ffunction-sections -fdata-sections -std=c99 -MMD -MP -MF"emlib/em_leuart.d" -MT"emlib/em_leuart.o" -o "emlib/em_leuart.o" "C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_leuart.c"
Building file: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_prs.c
Building file: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_rtc.c
In file included from ../src/main.c:20:0:
C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc/em_chip.h: In function 'CHIP_Init':
C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc/em_chip.h:181:3: error: expected expression before 'uint32_t'
uint32_t rev;
C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc/em_chip.h:182:3: error: 'rev' undeclared (first use in this function)
rev = *(volatile uint32_t *)(0x0FE081FC);
C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc/em_chip.h:182:3: note: each undeclared identifier is reported only once for each function it appears in
make: *** [src/main.o] Error 1
arm-none-eabi-gcc -g -gdwarf-2 -mcpu=cortex-m0plus -mthumb '-DDEBUG_EFM=1' '-DEFM32HG322F64=1' '-DDEBUG=1' -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/examples/textdisplay" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/config" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/CMSIS/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/bsp" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/drivers" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/Device/SiliconLabs/EFM32HG/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd/ssd2119" -O0 -Wall -c -fmessage-length=0 -mno-sched-prolog -fno-builtin -ffunction-sections -fdata-sections -std=c99 -MMD -MP -MF"emlib/em_prs.d" -MT"emlib/em_prs.o" -o "emlib/em_prs.o" "C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_prs.c"
make: *** Waiting for unfinished jobs....
arm-none-eabi-gcc -g -gdwarf-2 -mcpu=cortex-m0plus -mthumb '-DDEBUG_EFM=1' '-DEFM32HG322F64=1' '-DDEBUG=1' -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/examples/textdisplay" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/config" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/CMSIS/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/bsp" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/drivers" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/Device/SiliconLabs/EFM32HG/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd/ssd2119" -O0 -Wall -c -fmessage-length=0 -mno-sched-prolog -fno-builtin -ffunction-sections -fdata-sections -std=c99 -MMD -MP -MF"emlib/em_rtc.d" -MT"emlib/em_rtc.o" -o "emlib/em_rtc.o" "C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_rtc.c"
Finished building: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_leuart.c
Finished building: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_prs.c
Finished building: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_rtc.c
11:28:46 Build Finished (took 2s.27ms)
发帖数: 8
注册日期: ‎07-28-2017
回复: SLSTK3400 使用问题
08:04:19 **** Build of configuration GNU ARM v4.8.3 - Debug for project SLSTK3400A_textdisplay_5 ****
make -j4 all
Building file: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_assert.c
arm-none-eabi-gcc -g -gdwarf-2 -mcpu=cortex-m0plus -mthumb '-DDEBUG_EFM=1' '-DEFM32HG322F64=1' '-DDEBUG=1' -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/examples/textdisplay" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/config" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/CMSIS/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/bsp" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/drivers" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/Device/SiliconLabs/EFM32HG/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd/ssd2119" -O0 -Wall -c -fmessage-length=0 -mno-sched-prolog -fno-builtin -ffunction-sections -fdata-sections -std=c99 -MMD -MP -MF"emlib/em_assert.d" -MT"emlib/em_assert.o" -o "emlib/em_assert.o" "C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_assert.c"
Building file: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_cmu.c
Building file: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_ebi.c
uint32_t rev;
arm-none-eabi-gcc -g -gdwarf-2 -mcpu=cortex-m0plus -mthumb '-DDEBUG_EFM=1' '-DEFM32HG322F64=1' '-DDEBUG=1' -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/examples/textdisplay" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/config" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/CMSIS/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/bsp" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/drivers" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/Device/SiliconLabs/EFM32HG/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd/ssd2119" -O0 -Wall -c -fmessage-length=0 -mno-sched-prolog -fno-builtin -ffunction-sections -fdata-sections -std=c99 -MMD -MP -MF"emlib/em_cmu.d" -MT"emlib/em_cmu.o" -o "emlib/em_cmu.o" "C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_cmu.c"
arm-none-eabi-gcc -g -gdwarf-2 -mcpu=cortex-m0plus -mthumb '-DDEBUG_EFM=1' '-DEFM32HG322F64=1' '-DDEBUG=1' -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/examples/textdisplay" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/SLSTK3400A_EFM32HG/config" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/CMSIS/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/inc" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/bsp" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/kits/common/drivers" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/Device/SiliconLabs/EFM32HG/Include" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/glib" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd" -I"C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/reptile/glib/dmd/ssd2119" -O0 -Wall -c -fmessage-length=0 -mno-sched-prolog -fno-builtin -ffunction-sections -fdata-sections -std=c99 -MMD -MP -MF"emlib/em_ebi.d" -MT"emlib/em_ebi.o" -o "emlib/em_ebi.o" "C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_ebi.c"
Finished building: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_assert.c
Finished building: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_ebi.c
Finished building: C:/SiliconLabs/SimplicityStudio/v3/developer/sdks/efm32/v2/emlib/src/em_cmu.c
08:04:24 Build Finished (took 4s.705ms)
发帖数: 8
注册日期: ‎07-28-2017
回复: SLSTK3400 使用问题
问题列表:
11:30:55 **** Incremental Build of configuration GNU ARM v4.8.3 - Debug for project SLSTK3400A_textdisplay_5 ****
make -j4 all
uint32_t rev;
11:31:00 Build Finished (took 4s.348ms)
发帖数: 8
注册日期: ‎07-28-2017
回复: SLSTK3400 使用问题
make -j4 all
uint32_t rev;
发帖数: 2,384
注册日期: ‎10-14-2014
回复: SLSTK3400 使用问题
There are errors showed based on your log. You need to fix them one by one.
On my side the example pass buiding after I import it SS V3.
