WT12 Apple Authentication Co-processor Access
We have a product with an Apple authentication co-processor connected to a WT12 Bluetooth module. We are registered with MFi and can communicate with Apple devices by Bluetooth. We would also like to be able to access the Apple co-processor directly by commands from the WT12 serial port. Is there any way to do this? I have looked at the iWRAP PIO commands but they would be too slow to do a software I2C to the co-processor. iWRAP commands to read from and write to the co-processor would be ideal but I could not find any such commands.
Thank you.
Re: WT12 Apple Authentication Co-processor Access
at the beginning, please keep in mind that all matters related to our special iAP-enable firmware should be discussed privately.
So you might want to consider creating a private technical support request, where our team will be able to answer all of your questions.
Anna
