WGM110 sd_card write
i work with WGM110 with BGlib API, 1.0.1 sdk version. It communicates with an extern MCU.
When i write some info in a file, if i turn off the module without to close the file, causes it some error?
Re: WGM110 sd_card write
Most likely it will corrupt the file, that's something you can easily try.
Tiago
