OTA to BlueGecko from smartphone App?
I wonder smartphone App reference source for OTA to BlueGecko.
so read "an1045-bt-ota-dfu.pdf "file. but when I coding smartphone app, I refer to smartphone App source.
I don't understand OTA process(config setting, file send process, and so on) and don't know to send *.ebl file method.
(but I tested to use ota-dfu.exe in BGM121-EVboard(ncp_host).)
so I want to know smartphone app reference source or smartphone app for OTA to blueGecko.
when you tell me to smartphone app, also App mannual, please.
read my post Thanks a lot.
have a good days.
Re: OTA to BlueGecko from smartphone App?
We do not have an OTA smartphone app available at this point.
Thanks~~
I understand your answer.
using smartphone  APP can't  OTA to BlueGecko(EFR32BG)?!
Correct. At the moment we do not have example of smartphone app that performs OTA. We are planning to add this feature into the Blue Gecko Smartphone App but it is not yet finished.
oh,ok.
I add two questions.
when do Blue Gecko add OTA?
and I'll make app that do you teach me OTA process?
The release schedule of next Blue Gecko app is not fixed. It will probably take at least one month from now before it is available.
The OTA process is described in the application note and we have a NCP host example that can be used as reference.
We do not have too much resources or expertise to help you with the smartphone app development. We are in the business of selling chips/modules, not smartphone app development.
