I can't run Serial DFU
I need to update the fw of wt32i , but I can't run the serial DFU . I get an error . I have tried to run it on different oss ,XP windows 7 10 and I get the same error . Are there any special requirements?
Re: I can't run Serial DFU
Have you solved this issue?
I can't run Serial DFU too.
I downloaded the latest iWRAP firmware to update firmware but I couldn't execute SerialDFU.exe.
I don't know why this error occurred.
computer configuration
Window 10 pro, 64bit x64
Error log :
Traceback (most recent call last):
File "DFUToolGUI.py", line 442, in <module>
File "wx\_core.pyo", line 7981, in __init__
File "wx\_core.pyo", line 7555, in _BootstrapApp
File "DFUToolGUI.py", line 57, in OnInit
File "DFUToolGUI.py", line 156, in init_frame
AssertionError
Thank you.
Hello @picdev@Mong,
The firmware release package has been lately updated. Unfortunately, the new SerialDFU release contains a bug, that is visible on some PCs (and therefore the application cannot be launched).
Our R&D is working to fix this. My apologies for any inconvenience, that it causes. I will let you know once the package is updated again.
Bartosz
Hello, Bartosz
Thank you for your support.
I am looking forward to your replies.
Mong
The firmware package has been updated:
http://www.silabs.com/documents/login/software/iWRAP-Firmware-Releases.zip
Bartosz
Thank you for quick response.
It runs well.
Mong
Thank you !!!
