How can I use the ECC library?
Hi anyone,
I want to use the ECC library to set up my device wishing to  participate in SE network,but when I compile the application,6 errors about ECC library occurred.Please see the accessory.
How can I do if I want to use the ECC library correctly?Please help me.无标题.png
Re: How can I use the ECC library?
Please follow our instructions in AN708 and AN714.
Besides having the certificates (test certificates will do for testing purposes), you need to make sure that in App Builder you have selected the CBKE Core Library, CBKE 163k Library or 283k Library (or both), and the corresponding ECC library with its library path.
Yuping Xiao
I have tried again,but the same errors maintained.Attaching my .isc file in attachments.
yeshuming
