BLE113 Event Priority vs While loop
I have an interrupt triggered by an external accelerometer used to bring my BLE out of PM3. This int triggers a timer. If a device connects, the timer event runs a while loop while a variable "connected" = 1. Outside the loop, I have a connection_disconnected event that sets "connected" variable = 0. Will the connection_disconnected event take priority over executing the while loop in order to bring the while loop to an end? Hopefully this makes sense.
coltonrb
Re: BLE113 Event Priority vs While loop
No, it won't, there is no preemptive execution in BGScript, each procedure/even will execute all the way until it exists. If you place infinite while loops conditional to some externally set data then your application will freeze.
Tiago
