BGlib evt_sme_ap_client_left event causes
i work with WGM110 with BGlib API, 1.0.1 sdk version. It communicates with an extern MCU.
The module is AP mode. With my pc i connect at the ssid of the module. The pc is very near the module (40-50 cm). Sometimes happens the pc disconnect from the network (without apparent reason) and the module see the event "evt_sme_ap_client_left".
What is all the cause that trigger the event "evt_sme_ap_client_left" excluded volountary disconnection or exiting out of wifi range?
Re: BGlib evt_sme_ap_client_left event causes
Are you sure your windows pc didn't disconnect? Sometimes windows can connect to a known network without prompting the user.
Tiago
