Thunderboard react debugger mode
Does Thunderbird React only support 'out' in debugger mode?
Re: Thunderboard react debugger mode
according the user guide there is a 10-pin debugger connector that was used to debug/flash the board with an external debugger.
http://www.silabs.com/support/getting-started/bluetooth/thunderboard-react-getting-started
Hi!
i mean selecting debug mode.
so i can connect 'OUT' mode but not 'MCU' mode
@kimkyeyoung
You could follow the guide in the section of 6.5 of below document (page 37).
http://www.silabs.com/documents/public/user-guides/ug164-thunderboard-react.pdf
If you are using an EFM32 STK to debug this thunderboard react kit, yes you need configure the STK as 'OUT' mode.
I cannot find adapter configuration tab to set the debug mode to out. Could you please check what's wrong with it?
@rzhou
What board you are using as the external debugger?
You could see the setup in page 37 of this document.
@delu
Yes, I followed the instruction. I am using the main board of SLWSTK6222A (EZR32WG 915MHz Starter Kit), the adapter board SLSDA001A and the thunder board. But in the instruction, the dialog has three tabs while the dialog in my Simplicity Studio v4, there is just 2 tabs
what is in the instruction:
What I saw in the IDE
It looks like your board was not correctly detected.
Maybe you could try the simplicity commander to confirm it works or not.
