Can I chose big-endian mode on EFM32
Can I chose big-endian mode on EFM32? If yes, How?
Thanks.
Re: Can I chose big-endian mode on EFM32
I guess below link helps:
http://infocenter.arm.com/help/index.jsp?topic=/com.arm.doc.dui0552a/I1835.html
https://en.wikipedia.org/wiki/ARM_Cortex-M
You could check the EFM32 endianess (little) by reading out register SCB->AIRCR.
Hi @netprince,
You cannot select big endian mode on EFM32.
Endianness is a design time instantiation option on ARM cores, and you will find that the ENDIANNESS status bit in SCB->AIRCR is hardwired to 0 on EFM32 devices just as it is on every other Cortex M-series standard product of which I am aware.
John
