BOOT_E102 - Bootloader Requires a Crystal
by <a href="http://community.silabs.com/t5/Welcome-and-Announcements/Community-Ranking-System-and-Recognition-Program/m-p/140490#U140490"><font color="#000000"><font size="2">Hero Employee</font></font> </a> Tabitha ‎10-06-2017 06:11 PM - edited ‎10-11-2017 10:41 AM
See the Errata sheet for your device to see the complete description of this errata and affected products:
www.silabs.com/32bit-errata
Affected Devices
The following table shows devices that will exhibit the failure mode.
Device Family Device Revision Fixed Revision and Date Code
EFM32HG all (most recent is B) B devices, PROD_REV greater than or equal to 0x8E, date code greater than or equal to 1801
EZR32HG all (most recent is B) B devices, PROD_REV greater than or equal to 0x86, date code greater than or equal to 1801
Additional Notes Regarding the Failure Mode
Versions of the production bootloader prior to v2.06 require a crystal. Version 2.06 of the bootloader has been updated to no longer require a crystal, since one is not needed on these products.
Systems intending to use the production bootloader that do not include a crystal will not be able to run the bootloader on affected devices.
For systems intending to use the production bootloader on affected devices, add a temporary crystal to the design that can later be removed when it's no longer needed.
This issue will be resolved in future devices, but the date code of the fixed devices is not yet available.
